AGS
- Joined
- Feb 13, 2023
- Messages
- 301
Hi all
I have come across a problem with my controller when I try to set temperature settings using the MQCON app and they won’t save.
I also only have one set of temperature configurable settings on the app for my iPad, Teranovo version.
I have seen some screenshots of two sets, one for the controller and one for the motor. Maybe they are pc or android versions? Mine doesn’t say which of the two I have, so I’m guessing it’s for the controller.
I have tried the following:
Temperature setting
Stop Output Temperature (C) 90
Recover Output Temperature (C) 80
Current Limiting Output Temperature (C) 70
But when I save then switch everything off and back on again all three values revert to zero.
I can change and save other parameters ok, for example I can change my ebrake current from 50 amps to 30 amps and the new setting saves ok.
So I’m trying to figure out if my Risun controller temperature is not user configurable and its factory set.
My motor also has a temperature sensor which is wired to the controller through the hall sensor connector. But I have no way of setting this up on the app either.
Does anyone have any insight into how the motor and controller temperature monitoring works on the Risun version of the Sabvaton controller, or if it works at all?
I am considering fitting an external temperature meter so I can actually see the controller temperature. My controller is enclosed in a box so I’m concerned that it will get hot and I don’t want it to overheat and damage it.
I have this in mind, with the probe clamped to the heat sink. DC-12V LED Digital Thermometer Temp Sensor Meter NTC Probe -50 ~ 110??C Detector | eBay or may a slightly more sophisticated one with a relay output so I can set the maximum temperature at 90C and cut the motor via the brake switch input to the controller.
The parameters screen shows controller temperature at 25C and motor temperature at 1C without running the motor, so fully cooled down. These are clearly wrong because my bike is parked in my garage hasn’t been used overnight and the thermometer on the garage wall says 10C.
I have attached a couple of screenshots.
Temperature setting
