Routybouty
Hi!
Little background: I bought a cheap Chinese 1000W kit for my bike I've had for 17 years (got it when I was 13). I assembled that and have had a blast riding it around town. Anybody I have let ride it has always come back with a big grin! I started a little awhile ago a new, more powerful Ebike, aimed for my work commute. The commute is ~19mi with about 25% city and 75% highway (low use highway 55mph limit).
Here's what I have so far:
2009 Kona Dawg Supreme
Crystalyte H4080
Adaptto Mini-E
20x HK 4S 5A Lipo (20S 4P battery configuration)
Some pics!
Kona
Receiving the motor...
Adaptto Mini next to a Lyen 18 FET
Planned area for mounting the controller, made a small bracket
Cut out a carbon fiber bottom tray for the batteries (this is actually V1, I had to redesign slightly)
V2 with headlights mounted
This is a horrible shot, but roughly how the batteries will sit
Charged and tested 21 batteries, I bought one extra to throw out the weakest
Here is the simplifying of the wiring. The packs are assembled in series "bricks" of 5. Then 4 "bricks" will be paralleled
This is how I made the parallel connections to the 4 "bricks". The controller is the single side in the middle with batteries out the other surrounding it. I wrapped it with desoldering braid to keep it all tight and provide some copper (then soldered of course)!
Headlights!
I flipped the brakes to match a motorcycle, front on right
Quite a bit to go still.
Securely mount the batteries
Finish truing the motor and wheel
Finish wiring
Torque arms
Probably a bunch of other things
Work in progress, thanks for reading!
Crystalyte H4080
Adaptto Mini-E
Some pics!
Kona
Headlights!
Finish wiring
Torque arms
