johnrobholmes
kiwifiat said:johnrobholmes said:Kiwifiat, you are comparing two different motor winds with a fixed amperage controller at the same throttle. If you adjust the amps to 37.5 and the throttle to 67% for the 3004 motor the curves are almost identical. The throttle and amp amounts need to be adjusted by 4/6 and 6/4 respectively for an apples to apples comparison.
The battery is the same, the controller is the same, the copper fill is more or less the same, only the wind is different. How much closer to apples V apples can you get, do you really expect the guy who chooses the higher N.m/A wind to drive around the place using 67% throttle so he gets the same poorer performance as the faster wind?
I was trying to illustrate one method of comparing watts to watts if you have a fixed voltage but programmable controller. Many controllers have a speed setting that makes running a high speed motor at lower max speed a simple change. My wife's ebike runs a 30mph on 36v "fast wind" MAC that is limited to 65% throttle, and with higher phase currents it acts no different than any other setup. Range is the same, acceleration the same, top speed the same. I don't expect anybody to do anything at this point in my life, but why waste your time on the forum asking questions just to dismiss the responses?
John's method of selecting battery voltage for each wind that result in the same speed is also a watt to watt comparison. If one has the luxury of many packs to choose from, then it is always best to select the voltage that matches the wind to meet your speed needs. But in some cases, like my wife's bike, you make it happen in other ways because the battery is already purchased. 67% throttle limit and reprogrammed current is the cheap way out
