Rix
100 TW
John in CR said:Rix said:I should recant my statement, I am into performance driven hubmotor powered machines. Because I love the simplicity of them.
I was referring to the motor choice, not necessarily hubmotor or not. I told you about a hubmotor in the similar weight range, that was close to double the torque. I need the phase-to-phase resistance of the 5403 to more accurately compare. Since I haven't tested it, and it sounds like you might be able to hammer on it, I would have fixed you up at factory direct cost, and guarantee far greater performance. I understand that you're currently tied into the Xlytes for now, which is what really prompted my statement.
If you're truly performance driven, the I suggest getting beyond hearsay, and compare motors based on the physics. You know now that winding does nothing in terms of increasing the performance limits. Simply comparing the surface area of the stator in the magnetic gap, along with the radius tells a tremendous amount. Then look at the current handling by comparing phase-to-phase resistance, while at the same time considering the relative Kv's. Add no-load current at several significant rpm and you're well on your way to being able to compare different motors on paper pretty well.
I miss understood you. Yes, I am involved with US Crystalyte importer. In fact, I will be testing a modfied variation of TC4080 very soon. Word I have gotten so far is Its supposed to be identical to the 5404 in terms of performance, and durability, but 4kg lighter which makes me very happy as thats comes out to about a 9 pound reduction in unsprung weight. Huge positive affect on handeling. Doesn't sound like anything I got going on can touch your motor though. You got any other info that you can share or a site to direct me too?
