Hi
Njay
Q2/R2: Yeah, something altogether different. Not going to worry about it for now cos I’m only going to mod one controller to keep the research simple,
and if we get success – then worry about mating two controllers. :wink:
Diodes: If you look at the last schematic at the EBS Emulation, far left, there’s a +5V out with D0 1N4148 inline. That diode exists on the controller board, so I did not add another one.
FH Stuttering: I found the source of the problem; The SC HE Signal wire broke off at the solder joint on the controller PCB,
likely my fault when I inspected the board for the Sense mod. All of those wires are under strain when there should be none at all – so I’ve clipped them and am now in the process of soldering in small extensions. I have to tell you honestly that I thought I had a blown controller.
I’ll know for sure though when the repair is complete later today.
But talk about having a fright though, and right before Halloween. So – to affect the inspection and possible replacement, I had to remove the entire triangle fairing and battery pack. I was just saying on another thread eariler that if I ever had to dig in that far into the bike I’d move that pack backward an inch to gain more maneuverability at low speed and for parking. Well, I’m eating crow now.
What I should do is cut the long motor umbilical and make it real convenient to R&R the FH controller like the rear; make it identical so I don’t have to do this again. Sheesh; how laborious.
Anyways – that’s where I’m at: Knee deep in repair. Once I get the FH sorted, then I can look at Sense again.
This work is making me thirsty.
KF
