battman said:
If you still want to pursue low ohm meter you could try this:
http://www.aeroelectric.com/articles/LowOhmsAdapter_3.pdf
I built it and it worked well.
Definitely a workable solution if you have a high quality meter to go with it. For milliohm resolution you need a meter that can read to 100 microvolts (1/10 a millivolt)... Most 3.5 digit meters might resolve down to a millivolt with a few counts of noise thrown in at that level.
Using a current limited bench supply at 1 amp will allow you to read 1 milliohm with a millivolt capable meter. Again, you will have a few counts of noise to deal with plus errors due ohmic heating due to the high test current (which might be a good thing when testing power connections).
The Valhalla igniter testers are designed for testing things like blasting caps and rocket igniters. On the milliohm range they are designed so that absolutely no matter what goes wronnng inside them they cannot and will not put out more than 15 milliamps of current.
The HP milliohm meter is a very nice device. I sold mine when I got the 3458A's. I should have kept it... I occasionally have the need to measure things it can do well, but the 3458A's don't (or is not worth risking damaging a high dollar meter on)
Ebay can be a wonderful source of very sophisticated test equipment at dirt cheap prices. My lab has a couple million dollars (retail) worth of equipment that was acquired for under $30,000. It can also be the source of high dollar, you bought it... it's yours, boat anchors that belch nasty smoke when you plug them in.
I do electronics for a living, so can easily justify most of the rather extravagant equipment. If I need a piece of equipment for a project, I can almost always buy it there for less than I could rent it for a week! But a couple pieces were acquired more for the "wow" factor... like wow, that's neat... I'll bid a few hundred bucks on a $250,000 gizmo... and occasionally wow... nobody else wanted it more that week. Who knows, someday I may actually NEED that 500 gigasample/sec transient digitizer.
