nieles
ZapPat said:Very good explanation, Marty!
One problem with these RC controllers is that they are made to be very close to the battery, so thus they can get away with using less bypass capacitors on their main DC power bus.
Think of capacitance being the opposite of inductance. So the more inductance you add into your circuit (between the battery and controller), the more bypass capacitance you also need in (or very close to) your controller. Also make sure these capacitors are good quality ones. I use the Chemi-com KZE series as they have very low ESR for the price, but you may also want to put a good film type capacitors too into the mix too (this is for high frequency bypassing if needed). As others have mentioned, always put these as close as possible to your controller's DC input - specially so for the high frequency film type caps if you use these too.
One thing also to remember is that inductance is not really wire length, but really wire loop area. This means that it's better to run your DC bus wires (+ and -) right beside one another, and twist them also if possible.
if you add more capacitors you also get a larger spark when you connect them.. with many low ESR capacitors the power could even "burn" a hole in you connector.
i got this tool from an rc site.. http://www.scriptasylum.com/rc_speed/_nospark.html what you do is put an extra connector on your batteries with an resistor in series, and when you plug this connector in the capasitors get charged.. then you can connect the the large connectors.. read the info in the link. i can't explain it very good in english.
