Here are a few pictures.
You can see the yellow is really stunning against the black steel parts and carbon fiber panels.
I am very glad I decided to extend the swing-arm. That added 2 inches, looks fine and, judging by the looks of it, will really help with the CG and stability.
When placed next to the Mountaincycle, you can see a few obvious things. First, the seat is way farther forward. That is partly because the Mountaincycle seat is actually too far back. The subframe is adjustable on the Mountaincycle and I plan on adjusting it forward a bit. Aside from that, I wanted the yellow bike to have a more forward bias to arrest some of the massive wheelie tendency it will have. Oh, the bike really needs a longer stem. This is one I had lying around. I will order a longer stem shortly. I will probably go with 35 to 50mm longer.
The wheelbase of my Mountaincycle is 45 inches. The yellow bike is 50.5 inches. That should be perfect for my needs. They bikes looks the same length in the photo. However, that is an optical illusion based on the longer bike being behind the shorter bike. I took a picture of the front tires so you can see that the yellow bike is actually nearly 6 inches longer (the rear tires are perfectly in line with each other).
You can see the wheel/tire combination looks pretty much spot on for this bike. Both tires are Kenda 24 X 2.5 inch. The rear wheel is a 2.5 inch wide Motoped rim. That widens the rear tire quite a bit compared with the 1 inch wide Sun Ringle front rim. These are massively strong wheels. I have no doubts about the durability of this bike.
One last item; the head tube angle is nearly identical on these two bikes. It will be interesting to see what twice the weight and twice the power does to the riding experience when comparing the two.
Matt
