Hi all. Yesterday I decided to try the new version and disable the advanced torque sensor calibration function. Because after stopping in the cold, I received error E02 every time. As long as the engine was warm or the outside temperature was above 10 degrees, everything worked fine. But yesterday things got really bad: When I tried to use the latest version of the configurator, I received an error. Then I tried to check the operation of St-link using St visual programmer and I finally turned the motor into a brick. I realized that my cable was working and after some time I was able to restore the motor using St visual programmer. But the configurator still doesn't work. When I try to program it gives an error: process_begin: CreateProcess(C:\Users\y\Desktop\TSDZ2\TSDZ2-Smart-EBike-1-20.1C.
2-update-3\tools\cygwin\bin\sh.exe, C:/Users/y/Desktop/TSDZ2/TSDZ2-Smart-EBike-1
-20.1C.2-update-3/src/controller/../../tools/cygwin/bin/sh.exe -c "echo \"Cleani
ng files...\"", ...) failed.
make (e=216): Error 216
make: *** [clean] Error 216
Cleaning failed!!
Press any key to continue . . .
I have an old laptop with Windows 32. Could this be the problem? And how to restore the configurator (at least the old version)?
Thanks.
Cleaning failed!!
Thanks.
