Jay64
Well, mine certainly does have speed limitation.
Jay64 said:Well, after hearing that others are running 36v with their ezip without blowing up their stock controller I started to build a quick ghetto DeWalt pack. But then I remembered that my bike cuts out at 20 mph, which it already hits with my 28v Milwaukee packs, so why should I bother putting 36v on it? All that would do would add top speed, right? But if it cuts off at a set speed, then the extra volts wouldn't make a difference, would it?
I dunno... I suppose over-volting is one way: you should be able to exceed the speed limit (32kph?) if there is none.How2 said:Tyler.. how is it we find out if there is speed cutoff on the motor?
Jay64 said:I believe for mine it is a contoller speed limit. I guess I will try to wire up the 36v packs and see if it goes faster then the limit or not. Maybe it is a ratio of the availalbe power.
How2 said:EcoForumZ said:K&N Model # SN-2580PK I bought it from K&N's website they are located in Riverside, CA so I got it the next day.
http://endless-sphere.com/forums/viewtopic.php?f=4&t=4687&st=0&sk=t&sd=a&start=30
hello again Eco.. can I ask what you paid for this beauty of a filter? Because I am out of state, I have to find a local store here that carries it. According to their website, there are about 4 possible stores within 6 miles of me so hopefully I'll strike gold... but wondered what the price is. Thanks again!
Jay64 said:yes, I do have an '07 model. And I definately have a limiter. So I guess I will not test the 36v setup on this until I buy a different controller. I'm really close on my motorcycle build right now anyways, so I am paying more attention to that at the moment.
docnjoj said:Hey EcoForumZ! Did U drill any holez yet? I really like the torque curve of the My1018 and even if my 16" hub is successful, I may keep the chain drive motor system. The noise level is almost tolerable with the sound deadener, and with Lifepo4z it works great!
otherDoc
Jay I'm not sure if someone answered this or not. I can't check right now. The chain adjust is in my owner's manual and the one on the web. The wrench you need is a 17mm cone wrench.Jay64 said:Ok, now i know why I didn't do that plan earlier. It can't be done. I have to take out the battery contacts (which I can't do when the battery is in place) in order to take off the wires that connect them to the bike. So I got frustrated with the whole non-working lock mechanism and took a screwdriver and hammer to it. Bent it out of the way and slid the battery pack out. The stock pack weighs 15 lbs. The two Milwaukee 28v packs I am replacing it with weigh about 3 lbs. 3 of them come out to exactly 5 lbs. (At least those are the numbers off my crude bathroom scale, so I guess I shouldn't say 'exactly'.) I think I will be able to re-charge the 28v packs at work. A little less obvious then a big cord going right to my bicycle in the middle of the break room. So I will be able to make it back home with no problems without the support of the stock pack. I will try to build another box that has room for 3 of the packs to give a little farther range, then I should be able to make it back home with out re-charging if I have to.
One thing I noticed while working on the bike today is that the motor chain is a bit loose. I looked through the manual on how to adjust it and there is nothing in there regarding the electric portion of the bike. Everything in there is just regular bicycle stuff. So I figured I would try to just wing it. I found the two slotted wholes on the mount plate and loosened those bolts and I tried to adjust the bolt that looks to be an adjuster bolt, but it wouldn't budge. There looks to be a very skinny nut on the axle between the frame and the motor mount plate. I'm guessing that I might need to loosen that, but I don't have a wrench in that size which is that skinny. From the looks of it, I have to take the wheel/motor completely off the bike in order to adjust it. That seems really ridiculus to me.
vanilla thanks, but the Unite page (http://en.unitemotor.com/ProductView_41.html) shows 2 models of 1018 one @ 24V 250 w and one @ 450 W. Currie says there using the 450 w. TNC sells the 250 w. I'd like to find the 450w version. Torque for 450 is rated 1.43 Neut M for 250 it is 0.87 Neut M.vanilla ice said:The 24v is $50 at TNCscooters last time I checked.
I think yer correct, but we really don't know what he's got in the case... I don't recall any noload comparisons before installation.vanilla ice said:Didn't the dude with the dual 1018 Currie get the 2nd motor get it at TNC? He never mentioned any problems with the motors behaving differently.
