Philistine
- Joined
- Aug 15, 2010
- Messages
- 1,736
I have seen a few folks using what look like printer serial cables to achieve a one plug solution for balance charging lipo (ie, they have all the balance wires and the two charge wires put into the serial plug, so they just plug one plug in for balance charging. I think the members I saw doing this were El Steak and Aussie Jester, but I could be wrong.
I am building a 10S battery for a friend who I would like to be able to have them just plug one plug in, and balance charge. But my question was, when you run the main power/charge leads into the serial port plug, how big does the wire you use for the charge lines need to be (if say you are charging 10S at 10amps)? I would have thought that there would be too much resistance with the + and - charge leads going through such a small pin, or is 10amps not such a big deal? Could the wire you use leading up to the pin be the same kind of thinnness as balance leads?
