danjpendleton
Hello,
Ive been deciding on whether I should run the Crystalite HS3540 or the HS4080. If your not familiar with these two motors, the 3540 has a 35mm wide stator, the 4080 is 5mm wider at 40mm. Obviously the wider stator is beneficial in terms of overall speed and acceleration. Ive spoken to Justin at ebikes.ca and he told me that they dont sell the 4080 because it is too wide, and will not allow a 7 speed freewheel in a standard 135mm mountain bike frame. This is not a concern for me because my bike is a cruiser single speed that I plan to run off 72v 40A max. (more of an e-moped) I can spread the dropouts a bit if necessary as well because it is a steel frame bike.
So.... Justin offers the 3540 at just under 400 shipped to my door. PLUS>>>>>>>they remove and remachine the wire exit cap on all of the clyte hub motors so that the cable is held snug to the axle and less likely to get cut through by the rotating seal on the side cover plate. As well, theirs are a later version of the motor with a deeper wire slot in the axle and a fibreglass sleeve over the cables for additional abrasion protection.
Now from what ive read on the forum, anyone in my situation ops for the 4080, because more GO. But where can I find one that isnt going to have wire cutting issues. Ive also read that the 12AWG phase wires are not teflon in the 4080? and that under certain loads they can short? this could be hogwash because I read it on the internet.
So....does anyone have a good source for the 4080 in the states? and is it really even worth it over the hs3540?
Heres a pic of the bike as is right now. its getting there.
