neithermovingnorstill said:
I think it might be possible to use a cooling system with a geared motor, and then insulate it with a sound barrier material, but that is entering uncharted territory. Which doesn't scare me, but I can just picture working on it for months and months.
The nature of sound isolating materials is that they're either
A) heavy materials, with moderately insulating properties.
In which case, you have added a lot of rotational inertia to your wheel, and a bit of thermal insulation.
Or,
B) Foam-type materials, typically functional only for high pitch stuff (or maybe it's low pitch? But my intuition says high pitch).
In which case, you have added a lot of thermal insulation.
Unless you had a liquid based cooling system that went in and then out of the sound barrier situation, you would have cooling issues. This might not be an issue if you're only running at 500 watts, but if you're pushing the higher wattage, it's no good.
I am very curious whether or not active noise canceling would be possible. I don't understand sound engineering. It's super cool, but totally out of my ballpark. I don't know if it would be effective in the open-environment, but I have seen the kind of press releases for some open environment noise canceling techniques. But that might not be on the hobbyist level. I know noise canceling is totally possible on the DIY level for headphones, though.
It's also worth talking to the few people who have filled their hubbies with oil. I would imagine liquid would damper the vibrational sounds, which I guess are mostly coming from the gears. You might find noise reduction if you have a very heavily filled oil cooling setup. You will loose some efficiency when you load a lot of oil, though. But I would think it's not that big of a deal with a light oil.
