Jozzer
John in CR said:Dave_S said:Jozzer said:The most efficient I know of is Cedric Lynch's "Thing'a'mobile" - he gets around 20wh/m at 50mph steady and can travel over 200 miles on a charge.
http://www.bikeweb.com/node/2601
It might look weird, but if everyone was driving one of these the world would be a nicer place!
That kind of machine is a worthwhile goal for any electric bike project. Combining speed with low power consumption is soooo much better than just brute force speed.!!!
Other than the tiny bit extra you give up to the wind due to the slightly higher average speed, it requires the same energy to accelerate to the same cruising speed. Efficiency at cruise is great, but brute force acceleration is top of the list, and it promotes the cause better than anything else.
John
"Tiny bit"?? "slightly higher"??
In fact it uses less energy to accellerate to speed since air resistance starts to grow exponentially from a fairly low speed. Consider, if it only takes acouple of hundred watts to propel you at 50mph, then all the rest of the power you produce is making you acellerate. If your vehicle already needs 5KW to travel at 50mph just to overcome wind resistance - well - acelerration will have taken a big hit!
It's fitted with a 30KW peak motor, so it's power to weight ratio is higher than the vast majority of ebikes here..it is NOT a slowboat!
Also, a vehicle with "brute force" power is more likely to travel faster and would save even more energy than a lower power vehicle if it were properly streamlined - making it all the more important.
