Effects of Partial Throttle on Controller Temperatures
Okay ran a few tests to see the effect of partial throttle on controller temperatures. With some interesting results.
The test setup was
Powersupply = 22.2V
Drive motor: SK3 6364-190kv
Load Motor: C8085-250kv
Load Regen Controller: EB306 EBS Level = Unlimited, giving approximately 1N.m of load.
Here is a graph of the regen load for reference. Note torque is relatively flat, so phase currents and motor heat will be fairly constant, but overall power levels will drop as speed drops.
Then I ran various controllers through a similar test.
1) First full speed, 100% throttle
- this is to get the ESC, motors etc all up to normal operating temperature
2) Reduce the drive motor throttle until speed just starts to drop
- this introduces switching losses into the controller
3) Reduce the drive motor throttle until the motor speed is roughly half the full speed from (1)
- typically this results in slightly higher torque by ~10%, due to the nature of the regen
- and we will get significant switching and diode losses etc.
All the controller went through this test except for the EB306 ebike controller, as it could not run the motor cleanly at full throttle, so it just did the 50% throttle test.
The list of controllers tesed so far are:
Summary:
- at 100% throttle all controllers are looking fine
- at 95% throttle all controllers start seeing significantly more waste heat
- at 50% throttle all controllers got uncomfortably hot, with many tripping internal temperature limits
- typically the larger the controller and the bigger the heatsink, the cooler they were
- the ebike style controller handled the partial throttle load the best, possibly because it is design to operate with significant PWMing of the phase current, or possible as it is just significantly larger with more thermal mass, and more surface area to shed the heat.
- On bike tests have seen much lower ESC temperatures. Possibly reasons are more air flow & lower duty cycle.
- On the bike it is more typical to be:
---- full throttle on the flat, with minimal controller PWMing
---- going up a hill for a bit with significant current limitting kicking in causing all the ESC heat, followed by going down hill with either 0 or 100% throttle that gives the ESC a rest.
---- waiting at lights or just pedalling
Conclusions:
- on bike tests to date I ahve done appear to have been very easy on the controller, given the much lower temperatures I have seen
- all of the RC ESCs to date have not performed well on a continuous partial throttle with a decent load
- if I can get a controller to work on the bench for the continuous motor loads I am interested in, then the controller should be fine out on the road.
