j bjork
Finishing up one of the batteries:
I opened a new tube of glue, thinking it was black.
It wasn't..
I went with it anyway, it should not be very visible when it is done
When mounting it I realized there was no room for the big washers,
luckily it was not too hard to get them off and go with small ones instead.
I decided not to put the display in the front cover of the battery, at lest not now.
It should be possible, but it would take a pretty advanced box to make a decent install.
I might be able to 3d print something in the future.
So what is needed to change batteries is take the seat off, the left side cover, 2 connectors, the front cover, then the battery itself.
That is 2 screws for the seat, one for the side cover and 4 for the battery. Well there are two dzus for the front cover too.
For the seat and battery I plan to use the same screws, If in a hurry it should be possible to just use a cordless drill with a 12mm socket. The problem is the 8mm head on the screw for the side cover witch makes it necessary to use 2 tools to change battery.
Maybe I should try to find or make a m6 screw with 12mm head.
I was thinking of some kind of snap in place solution, but a different screw is just so much easier..
On the other hand I will probably never be in such a hurry to change battery that I cant change tools.
It is more the thing that it should be quick and easy. I kind of want the bike to be comparable to a factory build
It wasn't..
