Compression of pouch cells, info/data
NullValue
100 µW
flippy said:
garolittle said:
Advantages of pouch cells … Easier assembly. Disadvantage… Lower energy density than 18650 (usually).
and they blow up.
if that is an advantage or not depends on who you ask here, some people actually think that puffing pouches is actually a good thing.... :confused:
I've heard that having the cells designed to be under compression, actually under compression mitigates that to a certain extent.
I have no idea.
But pouch cells are not all the same, and I've seen these dead shorted and they puffed, but did not catch fire.
We shall see.
yes, pouches are normally under compression to prevent delamination, something that simply is not relevant in 18650 cells as they have their own compression case.
i have seen several car crashes where the car did not catch fire.... :roll:
ps: the reason why phones and laptop do not have compression casings is simple: they are under VERY low loads. automotive ones are under extreme loads but weight is not a big concern (safety is) so they throw in half a ton of steel against the problem. RC gear like drones have stupid weight restrictions so they simply take the risk with plenty of drones ending up as flying balls of fire or batteries tossed in a ditch because they started puffing after a 20C+ discharge run....
Well said! :)
Well manufactured prismatic (pouch) cells should not puff unless they are abused IMHO. I think Lifepo4 cells puff because people stupidly leave them fully charged all the time or abuse them in other ways.
Been in the Rc aircraft hobby for over 10 years and lipo packs dont puff unless they are pushed too hard or kept at full charge. Unless they're one of the cheaper brands that are known for puffing like the turnigy nano techs used to do. Not sure if they've addressed that issue but that was one of the packs to be avoided a few years back.
Yes compression case is required for LFP pouch or prismatic.
The metal-cased ones need careful dielectric insulating between each cell as well as the floor and sides of the box
with a material that does not compress, or it defeats the purpose.
And a bit of puffing is inevitable for any bank used hard, does not necessarily mean "abused", it's not preventing it with compression that is abusive.
attachment.php
The modules currently shipping include the inter cell frames - but not the big heavy casing for the whole pack.
I'll use the frames with studs and nuts with end plates for compression, then build a case to provide rigidity, space for the bms etc.
Are there any published or derived specs on the compression pressure - too much is probably as bad as none.
back on topic...I've come up with a copper welding method that can work for me, though it's probably more fiddling than most people want to do.
I fold the parallel nickel strip where it passes over the cell, so it creates a tab sticking up.
My copper series connector is .1 mm copper folded lengthwise, dropped over the nickel tab, then spot welded from opposite sides.
I do have to make an adjustment on the welder when I go from the nickel strip to the copper nickel sandwich, but I do get strong welds when I do so.
If I make any big packs, I'll need a second welder to avoid that hassle - and new leads - the ones included are short af as well as not ones where the electrodes can be replaced - probably more insulation than copper too.
If I make jigs to do the folds uniformly, it shouldn't add all that much time to assemble.
I can also probably get the added height down - right now, doing it freehand adds about 1/2" top and bottom.
My folded and welded copper bus is effectively 25mm - which is overkill.
Current on series path will only traverse about .2 mm of nickel per cell.
I still have to come up with a easy method to support the pack.
I could probably get by with just an insulation mat, but I don't like the idea of the pack bouncing along supported by the series rails.
I can probably do fins on the bottom of the case so the battery weight rides on those.
EDIT:
This is the correct number.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
I communicated to a battery engineer from Zero motorcycles and and XXX-PSI is a helpful goal. They used flat pouch Farasis cells, and then potted them after testing. He mentioned anything is better than nothing, and not much of a benefit above that.
It's my understanding that prismatic means a pouch cell that is folded, but I don't have a reliable reference for that from the web. I will look for a good pic to show.
Interesting. I’ve always wondered about that. I want to research this too. It seems like the cylindrical cells would naturally have more energy density but I guess it depends on the cells.
the energy denisty comes from the chemistry used. prismatics as used in phones and laptops are made for capacity, not discharge power. even if you had the high current/lower capacity cemistry in a prismatic you need a compression case in order to prevent the angry pixies from "huffing and puffing" the cell apart. 18650 already have a compression case in their construction. technically a prrismatic is just a house fire in a plastic bag just waiting for someone to poke a hole in it....
in theory prismastics have higher Wh/L but that is due to their shape. cyclindericals have more "wasted" space in a volume. but they dont need compression so that offsets the acutal end result of how much you can fit in a specific volume.
generally 18650 is nearly impossible to beat in real life applications. the newer and bigger sizes are still too expensive and unreliable to be serious competitors.
I communicated to a battery engineer from Zero motorcycles and and 100-psi is a helpful goal. They used flat pouch Farasis cells, and then potted them after testing. He mentioned anything is better than nothing, and not much of a benefit above that.
That sounds insane! It implies that a pack with cells measuring 4" X 5" requires compression of 2,000 lbs. I doubt anyone builds packs anywhere near that. What do the automotive OEM's use I wonder?
3/8 allthread does 600lbs, so 4 of them will handle that with plenty of room to spare.
I've never heard of anyone cranking up pressure like that on pouch cells.
My drag race (Lonestar) cells are lightly compressed in a polycarbonate enclosure. It's stiff enough to inhibit swelling but nowhere near that kind of pressure.
I wonder if Zero actually does that?
excellent. Thank you.
The Battery engineer I spoke to also said, "anything is better than nothing" so apply a sturdy housing as protection, with a modest amount of compression on the flat sides and you are miles ahead of anyone who is just using duct tape to wrap a pack, with no compression at all...
Start with 10-psi, and see if that reduces voltage sag in your application.
it depends on the size of the pouch and the application. if the bags are small and in a high C situation: you want to really crank down on those bags to prevent any gases from forming.
people tend to forget that its force over surface, not just a point load.
I recall reading a cell datasheet that listed the pressure requirements, and it was nothing near that number. I'm fairly certain it was in the single digits (or maybe low double). Unfortunately I can't locate the datasheet...
pressure depends on the expected application. the pack of a volt has strech bolts to get the proper pressiure. for context: its the same style of bolt used to keep the cylinder head on the engine. offically they are a 1 shot use but nobody actually replaces them.
fun fact: even with several tons of force those cells in the gen 1 packs still burst into flames pretty often.
Operational preload requirement is different to damage mitigation and containment.
To put it into perspective, "normal" cell puffing is limited to the strength of the bonding around the perimeter of the outer layers. Past that pressure, the cell perimeter will peel open and start to expel the internals. So pack preload/ compression need not exceed that intrinsic limit.
Something else to consider: cells will produce small amounts of gas in normal operation, and if they are held in an extremely rigid enclosure, the pouch may over-pressurise and burst. Properly designed packs include a compression preload, but with a slightly elastic packing (usually a specialised PU foam) that allows for minor expansion of the pouch without significant increase in preload.
sorry, that logic completly falls apart with cylindrical cells. :wink:
the main reason you want flexibility in your pouch pack is simple: shock absorbtion. large compressed packs are quite sensitive to microshocks wich can mess up the contents of the pouch over time. especially in automotive and industrial applications. i have seen plenty of that from early pack designs from smaller companies that make small runs of application specific vechicles.
this is also why you dont want your pack potted (and a myriad of other reasons).
I'm starting this thread to create a reference concerning compression of pouch cells, and moving that existing discussion to here. The benefits and drawbacks of various methods, and the results of various levels of compression.
It is generally agreed upon that some compression is "good", but how much?
You need the resin in a potting to be soft enough to expand a bit as the cylindrical cells slightly expand with heat. Otherwise potting seems the safest way to deal with a battery in my mind. I can throw my potted battery down the street
Thanks for the info. Do you have a link to the exact putting material you use? If you can share it that would be great. Hope all is well. Thanks. Gary
potting is like a crumple zone in a car. great for hitting a tree, no so great at keeping the thing together for 200k, its either too brittle to survive the shocks for years or too soft to provide the support you need...
trust me, i tried many variations, even using vacuum chambers to fill batteries with a dozen types of resin. none lasted or geve the performance needed. the only thing it worked for was for diving gear.
