wyvernwaddell
1 W
I have a Catrike Expedition with 135 rear drop out for 26 inch wheel. I'm trying to find a 500 watt hubmotor that will take a 10 speed cassette (NOT freewheel) and fit in the dropouts. Might be willing to go with less wattage if that means it'll fit in the dropouts and I'm aware that I can add a spacer on the drive side to get the depth on the axle for the cassette. I figure with 10 speed gearing I probably won't have speed problems (grin). Anyone know of anything that would come close/fit the bill?
On a steel frame, I wouldn't hesitate to bend the dropouts a bit for width, but with this being aluminum, I really, really don't want to do that if it's at all avoidable. I already have a solution to avoid spinout of the axle.
I'm figuring on pairing it with a Baserunner and a flat battery and a Cycle Analyst.
If anyone knows where to find one of these unicorns-I'd sure appreciate a point in the right direction.
Thanks.
Just found this: http://www.mxusebikekit.com/mo/proshow.aspx?cateid=152&productsid=294
MXUS MX01C anyone know much about these?
Thanks.
