Jil
I start this post to continue the discussion started on the "Bafang M500-M600 thread" :
Are you using a low-powered ebike ? max 500 watts peak power and 250 watts average power.
If yes, what is your usage, your setup, your consumption depending on the conditions ?
What is the adavantage you see in using low-powered ebike ? More sport, more range, less batteries, less weight... ?
Jil said:Grin estimates that the GMAC (no freewheel) has a drag around 20-30 watts at usual speed, you can estimate that on a motor with freewheel it’s less than 10 watts.
As for the additional weight, I have made the calculation on Grin’s motor simulator, 10 kg more represents around 10 watts at reasonnable speed on steep hills. So, finally, on a motor with inner freewheel, the power needed to compensate the additional weight and drag is 20-30 watts only.
I have tested my GMAC yesterday and today with very low power (electrical assist between 30 and 50% of my pedaling power), I felt very clearly the electrical assistance (100 watts when I put 200-250 watts of human power), making the ride more enjoyable than without motor, and keeping the consumption very low (around 4 Wh/km).
That’s another way to use ebike, which I’m not really used to (the former version of my GMAC was mainly for fast commuting at 1000-1500 watts) but which I enjoy also.
