rumme said:
I was wondering if I took a dremel tool with a small cutoff wheel, and cut a thin slot lengthwise down the casing { where the wire is installed and soldered} , if the banana bullet connector would crimp strongly onto the wires , without breaking the metal casing of the bullet connector
I doubt it would work, but it depends on the type of crimper you use, and whether the metal of the connector you are using is intended to be bent and crushed. (if it is not, it'll just fracture and break or crumble, if not immediately, then as the joint is stressed/vibrated).
With a crimper made for round tubes, the only way a crimp will work and remain a good connection is if the entire tube is complete, so that when crushed into the wire, it holds that shape and becomes one piece of metal with the wire. (cold-flow).
There are some crimping connectors designed differently, in that they are open-winged to start with, or double-tubed like a double-barrel shotgun, with an open end in the center. The crimpers for those are designed differently than those for a round tube, as they fold the wings or centrally-slotted tube pair down together int he center, around the wire conductors, and then crush it all together (cold-flow) into one piece of metal.
Unfortunately many crimpers of this type don't ahve the force to do the cold-flow part, so the connection is not as good and the wires can be physically pulled out of the crimp, too. You have to get crimpers capable of a level of force that will cold-flow the metals together to make them good crimps.
A crimp that isn't cold-flowed is probably better to be soldered in addition to the crimp, to ensure it doesn't fail later--but the solder itself will cause other problems (wicking up the wire causing stiff places taht will break off under bending/vibration being one of the worst).
Most likely the bullets are not designed for crimping, and you'd be better off using contacts that are designed to be crimped, if that's the method you prefer.
