Silenthunter
- Joined
- Mar 24, 2013
- Messages
- 316
Good evening Guys,
I am trying to connect the Lyen 6 Fet controller with the Turnigy 6374-192kv and so far no results.
I mounted the sensors outside (distance between the sensors is 6mm) and about 2 mm from the engine. The engine starts and rolls smoothly but when I pass the 50% of the throttle it just stops. Tested without the load.
After about 30-60 seconds it starts running and the same scenario. Once I pass the mid mark on the throttle it does die again.
Do you know by any chance what is wrong?
Thank you!
P.S. I am trying to connect the electronics for the goped ESR 750H. Battery 37.5amps Li-Ion 18650
Thank you!
