keithvi225@gmail.com
- Joined
- Aug 24, 2019
- Messages
- 4
Just data for anybody that can use it. 10/19 purchased BBSO2 48v 750w mid Drive from em3ev.
I built a 15s battery pack from 12.5aH lithium soft pouches. No BMS and I am using an Active Balancer 1.2amp. I use Low Voltage cell monitoring to alert me when my cells get to 3.2v.
I bought a 15s battery charger with fan from Aliexpress. With the internal potentiometer adjustment pot I was able to lower the charger voltage down to 61.5 which was as low as the adjustment would allow.
My 15s pack now charges to 61.5v (4.1 per cell). My BBS02 gives me an OVER VOLTAGE (07) until i drop the voltage to 61.3v using a standard light bulb for a minute.
My reasons for building the 15s pack is simply because I had only enough cells to build 1p15s so I made it work.
Pros:
The pack is fast to charge using 3 amp charger and only charging to 61.5 volts.
Even when the pack is low enough to need charging the mid drive performance is still very perky due to the voltage.
My 15s battery pack discharging to only 48 volts before recharging to 61.5 volts should provide a long battery life.
Cons:
I have to drain the battery for 60 seconds(60watt load) in order to lower the voltage before riding.
Happy riding.
Pros:
Cons:
Happy riding.
