Schmuel The Cruel
- Joined
- May 1, 2019
- Messages
- 16
Ok, so I got hold of a multimeter. There is continuity between the stationary coil and all the way to the display pin. There is also contuinity on the hall sensor wiring.Because your readings dissapear, but not always, I think it would be something with the wiring/coils/connector.
If that is the cause, OSF will not help to solve that.
It is a pity you don't have a multimeter, so you must trust visible obeservations.
I'm not sure how I can test for continuity from the torque sensor to the motor (e.g. between the coils)?
