I have a stealth bomber clone that came with a mideuebike rebranded dinky 80/300 controller. I bought the bluetooth dongle (didn't come with one) so i could further tune it in the fardriver app but due to my over-excitement, I didn't save the stock tune before my issue started happening. At stock tune, my bike never tripped. It never shut off on its own, ever. But it was a snail off the line at full throttle, and it was a horrible hill climber. It caught up to speed though, hitting 90kmh on flat on full charge, no problem.
I use my bike primarily for work commute, which is 41km mostly straight and downhill with some hills, then 41km home which is mostly uphill, 82km round trip, 5 days a week if the weather permits it, all year long. I am a heavy rider, at 250lbs before full moto gear. The bike is a fat tire bike, so it's heavy, probably around 160-180lbs with a steel frame.
Because my controller is old and no longer supported (according to siaecosys) I can't change a lot of the settings as I get the "please use new BLE module" message. Siaecosys says the USB cable will work, so I ordered that and am awaiting it's arrival, but for now I have to make due with what I have. I can't change pole pairs, some RPMs in speed ratios, stuff like that.
Ever since I started my goal to achieve 5kw (70/200) The bike always trips and shuts off around the same spot going home, going up a hill. It shut off once waiting at a red light which was really odd. It NEVER shuts off going to work, where I hammer the throttle and burn more battery than going home due to the speeds I'm going.
Controller has gotten as hot as 77-80c, motor around 45c (i use temp laser gun for that) and battery around 45c (temp laser gun for that as well). The controller is too hot to touch, the silver area especially once I get home.
Could it be the controller overheating? I get the undervoltage alarm but I think that's just the app losing signal from bluetooth since the entire bike shuts off when this happens, display, controller motor and all. When this does happen, I pull over, wait 3 seconds, turn the bike back on and it works no problem gets me home which is a remaining about 6km from that point. I also don't think it's undervoltage alarm because my 72v battery sags to around 72-73v around there when this happens and on the way to work, I've sagged it to as low as 67 at times and it never tripped. The line amps were also under 40 when it trips due to my battery being at 60% or under.
So what could it be? I plan to get a ND72530 very soon just to run the thing at under half capacity as i would think that wouldn't heat up as much since it'll be under utilized, at 70 line, 200 phase around there.
Here are all my pics, motor, bike, battery, controller settings (limited), a screenshot when it tripped, and all that.
My battery is a Suzhou thinked electronic technology 72v 41ah 150a BMS (I think, had to translate from google lense), 2999 watt hours. Battery currently has around 4300km of usage. I don't know if it has bluetooth BMS.
Please note, I have changed a few settings since these screenshots. I have changed motortemp sensor to none, as CACU wasn't reading properly, maxrpm set to 5000RPM, low voltage protect at 63v, line current 70, phase 200. Field weakening is disabled (can't change it) and regen also disabled (i ride in winter, so should stay that way).
Thank you all in advance!
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
