cal3thousand
How difficult would it be to make a device that controls a relay and will switch it off after a preset time or current? Basically something that turns a cccv PS into a 'charger'
I suppose you could use one of the power timers spinningmagnets refers to, but rather than plugging it into the wall, insert it between the supply and the battery. A quick Lowe's search shows either 15 A or 40 A limits.cal3thousand said:How difficult would it be to make a device that controls a relay and will switch it off after a preset time or current? Basically something that turns a cccv PS into a 'charger'
Yes, unless there is a diode on the output of the charger or power supply. There is always a drain down resistor across the output caps
Specification
Operation Voltage Range 170 – 264Vac
Operation Frequency Range 45 – 65HZ
Output Voltage Range 0 – 60V
Output Current Range 0 – 17A
Efficiency (220Vac/full load) ≥89%
Full Load Input Current(220Vac) ≤5.1A
No Load Input Current(220Vac) ≤180mA
Volt Meter Accuracy ≤ 0.3% + 1 digits
Current Meter Accuracy ≤ 0.3% + 2 digit
Constant Voltage
Load Regulation (0-100%) ≤ 30mV
Line Regulation(198-264Vac) ≤ 10mV
Ripple & Noise (Peak-Peak) ≤ 30mV
Ripple & Noise (r.m.s) ≤ 3mV
Set Accuracy ≤ 0.3% + 10mV
Transient Response Time (50%-100% rated Load) ≤ 1.0ms
Constant Current
Load Regulation(90%-10% Rated Voltage) ≤ 50mA
Line Regulation (198-264Vac) ≤ 20mA
Ripple & Noise (Peak-Peak) ≤ 30mAp-p
Set Accuracy ≤ 0.3% + 20mA
Size(width× height× depth) 188×80×238mm
Net Weight 3.0KG
Package include:
1 x CPS-6017 DC Power Supply
1 x AC Power cable--china standard Plug(default), if you need other standard power plug,please contact us before order.
1 x User Manual
nutspecial said:http://www.aliexpress.com/item/CPS6005-Mini-Precision-Compact-Digital-Adjustable-Switching-DC-Power-Supply-OVP-OCP-OTP-low-power-60V/32320770541.html
Thanks Russell, I didn't notice that, it would be my style to order the 220 model.
Here's one that notes a 110/220 switch.
But can it output 300watts @ half voltage? 300w/10a @ 30v? I don't see why not?
How serial (2x for around 84v 8-9a) friendly is it? I don't see this as a problem either, but some confirmation would be great.
I didn't plan on carrying any charger with my bike yet. All my riding is sub 30-40mi round trip and there's no place to charge anyway.
CPS-8412(0-84V,0-12A
