Braddudya
- Joined
- Jan 30, 2022
- Messages
- 140
Hello,
I want to buy a charger that can be adjusted for different voltages. That way if I decide to increase voltage I can use the same charger. Even more importantly I want to be able to easily charge to lower voltages regularly so I avoid keeping the batteries at max for my daily commute.
Would something like this work well?
Programmable 60V/5A DC Power Supply Variable, Adjustable Switching Regulated Power Supply with 4-Digit Large Display Alligator Leads, PC Software, USB Interface for Lab Equipment, 110V~60HZ, (605P) https://www.amazon.com/dp/B08G19MMD1/ref=cm_sw_r_apan_glt_i_29EJ3KFJN785AMT5DV98
It looks like you can program over voltage protection which I would think kills the charge? Maybe this isn't the right solution so I wanted to share it here.
I would love to find a charger where you can just dial in any voltage and current (at or below pack safe limits) and it shuts down when voltage is achieved. I am hoping this might fit the bill.
Thanks everyone
Thanks everyone
