Simonvtr
Hi I have this posted in my build log but I don't think its getting the foot traffic to help me resolve this issue.
I have an odd issue or maybe I have something wired wrong. When I setup my mxus DD mother and my 12fet lyen controller I had a 3 speed switch. It worked fine but was told that when I install my CAv3 that the same switch does not work for the CA. So I purchase a switch for the CA from ebike.ca
The new switch hooked into the aux port of the CA. I setup the CA for Legal, Normal, Unlimited. When I went to test each of the setting nothing happens the speed is the same no matter which selection I have it on which is the middle setting of the lyen controller. So I plugged the old 3 switch back into the controller while the new CA switch was plugged into the AUX port of the CA. Now CA switch will only change if I have the Lyen switch on 3. If I disconnect the lyen switch the CA switch will do nothing and just run with the middle settings.
Am I supposed to have the old controller speed switch installed to make the new CA switch work thru the AUX port?
Or do I need to jumper the lyen controller connector for the speed switch and always have it on 3?
Thank you
Simon
Thank you
Simon
