Having contacted several Chinese distributors of 18650 batteries (many from the "recommended lists" posted in various areas on this forum) they are either exhorbitantly expensive to buy AND ship to California a complete welded pack w/bms or the loose cells without tabs are very reasonably priced but one has to either acquire the spot welding and metalworking skills to make their own pack. So...I was wondering if there were a weld-free option that is readily available and/or that others are using with any regularity that doesn't cost an arm and a leg? I know some in the forum have made rather complex copper or nickel strips with buttons punched into them but the combination and wiring still seems rather involved and not quite the plug and play option I was looking for that allows for removal of cells (if one were to have an issue possibly) as well as allow for many combinations of cells in series or parallel:
Found this:
http://www.dx.com/p/3-7v-1-x-18650-battery-holder-case-box-with-leads-100999#.U_Df-0hIPog
Is it possible to simply use the following spring and clip style battery holders (similar to the AA style battery holders in flashlights and other toys) for 18650 battery cells in a 12s5p configuration (for say, a 2.0ah 18650 cell of LG, Samsung, Panasonic etc) to get a 44.4v nominal and 10ah pack or are the included wires and spring/clips too flimsy/narrow gauge to support the amp draw, say, of an e-bike pulling 30-35amps without burning up or melting the wiring/clips?
Also, if one were to re-solder thicker gauge wiring but use the existing springs/clips in the battery holders shown, would that be able to handle the current and voltage? What are the issues surrounding using these kinds of snap together weld-free holders besides possible vibration/loose spring and tab connections, specifically surrounding the wiring and current handling abilities?
Thanks!
Dan
Found this:
Thanks!
Dan
