No, because (regardless of seller claims I've seen) all of these types of cells (non-cylindrical) need this to keep the cells from swelling which degrades them, and/or causes connection issues, etc.
Some usages of such cells don't push them hard enough to cause the swelling, which is good, so if yours don't, then you may not need this.
Cylindrical cells are naturally compressed by the design of their cases, but non-cylindrical cells are designed to be externally compressed, or rather, restrained so that they can't swell (which results in compression as they do swell)...if they can swell it can allow gas buildup in the cell between layers, disconnecting parts of the layers from each other and reducing capacity, etc. Another problem with swelling is it puts strain on the interconnects, and if the interconnects are solidly built the strain is instead passed to the internal connection in the cell between terminal and jellyroll.
For my SB Cruiser, I've got some ancient EIG pouch cells taht aren't compressed, but are slightly restrained by their cell holders secured with packing tape around the entire structure, but I am also not using these cells anywhere near their design limits (not even 1C out of the 5C they were designed to handle, and not charging to full, nor emptying very far most of the time), so I don't see swelling with them (I did have swelling in one cell some time back in a different pack of them, this cell had failed but it's unclear if the swelling caused the failure or was just a symptom of it).
Take a look at this similar cell's battery housing, for an example:
another variation
