Update - Recent additions. Added a 40 cell pack in the air cleaner space. That makes 200 cells in 20s10p. Swapped out the air forks for spring type, put on some Fasst Flexx bars, new 90/90 front tire and fenders. The weight is up 14 lbs to 234 lbs now with all that added. The motor current now set 200 amps higher at 800 amps. I have the quick map switch at 12,000 and 20,000 watts. I ride it most of the time at 12,000 watts. At lower speeds, 20,000 watts the bike has too much wheel spin and makes the handling difficult. It will reach its top speed of 53 mph on either setting. At 12,000 watts the controller will give all 800 amps at lower speeds. This makes clutchless blips easy and predicable. It's not all perfect yet. I'm still working on settings to remove some stopped and reverse start stalls. This bike is too much fun on single track. It is always in the right gear and ready to pull hard. It also climbs hills very well and has been getting 15 to 20 miles on a charge. That's enough for where I'm riding but I would like to explore fast charging.
