Adjusted the trim pot on the charger to make it really charge to 49.0V. It had been charging to 48.8V for several years. That will give me about another 1/2 mile of high energy cruising!
I have been seeing some threads on the forum about the voltage a BMS needs to get to before it starts balancing.
Here are the specs for the
EBay BMS I'm using:
44V 48V 50.4V 80A 12S Lithium ion / LiPolymer Battery Pack BMS for E-bike
12S 80A Li-ion / LiPO Battery protection board.
Applicable for
43V (3.6V * 12S) lithium battery & packs
44V (3.7V * 12S) lithium battery & packs
50.4V (4.2V * 12S) lithium battery & packs
Lithium battery (Li-ion)
Prismatic Lithium Polymer battery (Li-Po)
Technical Parameters:
Balanced current: 60mA (VCELL = 3.90V when)
Balanced for: 4.20 ± 0.05 V
Over-charged Protection: 4.2 ± 0.05 V
Over-charged Release: 4.05 ± 0.05 V
Over-discharged Protection: 2.9 ± 0.05 V
Over-charged delay: 5mS
Over-current Protecton: 80 A
Supports Max. Continuing Discharge Current: 80A
Max Charge Current : 40A
I think the text I bolded says that it starts balancing when the cell voltage is 3.9V (46.8V pack voltage). Does that look right to you guys?
-Warren
