ridethelightning said:
mobipus 72200, asi bac8000 controllers i suspect will give better results(just from trawling,not personal experience yet)
me i like smaller light bikes with good power/weight ratio over big heavy tanks...going over 100 on highway gets boring fast anyway.
id be maybe ditching the kelly, changing battery config for lower volts, more amps to use better foc controller with flux weakening, getting lightest "moto frame" possible...or use a stealth or raptor type frame..then the 273 will be fun.
Agree wholeheartedly on all points, but I think you might have meant the Mobipus 72600 rather than the 72200. For a 273 you're going to want huge phase amps.
Kelly is rubbish, 144v is in no-mans land for controller options/bms/charging etc. 20s is optimum for this kind of requirement. Select a winding option on the hub to land at ~90km/h on 72v nominal, the Mobipus or most other quality controllers (not Kelly) will easily run the motor to 1.5x base speed while delivering big punch <100km/h where you actually spend majority of your time.
0-100km/h in <3 seconds isn't easy - but I think you can get close with a hub bike, though perhaps not at 130kg+
