mxer
Fitted a 3 speed switch this afternoon and connected everything up X1red X2 green and GND etc into my Infineon EB209 board, Programmed everything up 80% 100% 120% switched it on and wound it up, Tried the switch and nothing changes ? Tried programming a couple of times with the switch in different positions and still nothing ? What am i doing wrong ? I did solder the GND to the board GND 7 (checking before for continuity on the main GND).....
Does it matter if X1 red and X2 green are the wrong way round ? (All shrinked up now and can't see) pretty sure i did it the right way ?
Also the XPD software say's select "switch" mode, There is no switch mode ??? Just "Toggle or Select"
....Anyway's I'm lost now so need some help folk's, Thanks....
