I was hoping you guys could lend me some expertise on building this battery.
Background: I am using a 3 D31M Optima Bluetop batteries in my bass boat to run a 36v troller. 75AH. They cost about $700 for all and weigh about 180#
I am looking to replace with a 36v 60AMP lifepo4 system, similar to this:
http://www.batteryspace.com/lifepo4-prismatic-battery-package-36v-10c-rate-with-led-balancing.aspx
Of course, being as frugal as I am, i am hoping to cut some costs from this kit.
I have found these prismatic batteries:
http://www.electriccarpartscompany.com/60Ah-32V-2C-br-LiFePo4-Lithium-Prismatic-Batteries-br-HiPower-LiFePO4-EV-Battery-br-USA-Stock-br-45L-25W-77H-in-br-114-63-195-mm-br-46-lbs-21-kg_p_51.html
which allows me to put together a battery for around $720
My questions:
1) since i am only looking to run a max of 42 amp draw (maximum of my trolling motor). Do i really need a battery balancer or BMS? the reading i suggest is that it is only really useful for high loads.
2) can i use a 12v circuit of the 36v to power my other electronics and act as a starter? With my current setup, i use one of the optima batteries as a starter battery for the big motor, which means it also gets alternator charging from my outboard
3) with an assembled battery system hold up in a marine environment? I know companies like Lithium pros build them and i assume they are just running prismatic cells... http://lithiumpros.com/product-category/marine/36v-batteries-marine/ I do plan to rubber isolate. However, they could get wet or submerged under extreme circumstances
Any other help or advice you could give would be great. Go easy on me, since i am just a mechanical engineer and electrons are a bit foreign to me
My questions:
