JA22
Hello,
I've got a Mototec 36V 1000w dirt bike, and speed and range are the needs, but obviously my budget would be 500-600 dollars. So Im looking for a 36v 20 to 30AH battery but ive seen this:
1. for the normal charge current, can I charge it with a lower amp charger? like 3A? (I know it will take a long time)
3. does this mean that when I'm cruising at max speed, 0 acceleration, the max speed being supplied to the controller is from 12.5Amps out of 25 amps from the battery? is there any way to get the fastest speed from the batter without damage to supply a controller max of 35 Amps? (Mototec 36V 1000w controller)
4. Or is this Cruising speed max speed (# 3 above)
5. For the mototec dirt bike, the bike has an inbuilt, stock fuse connecter at 35A. If I use this 25AH max peak 50Amps battery, will thiss keep blowing the fuse? Or will it not blow if the controller asks less than 35 Amps? (Also its 35A +-1A shown on the controller)
