liveforphysics said:Never thought I would be saying things involving the phrase "my wife", but it's a good thing.
Yes it is. And I'll bet you'll live longer too.
Congradulations!
nicobie said:liveforphysics said:Never thought I would be saying things involving the phrase "my wife", but it's a good thing.
Congradulations!
bearing said:Thanks a lot for the test!
100A, not really the 250A I was hoping for.
I'm impressed it handled such high motor frequency. 6700rpm with 11 pole pairs - more than 1200Hz.
Did you try any controller settings, like changing the phase advance?
Was it set to 32kHz switching?
liveforphysics said:Thank you Bruno (I will send it back to you if you want to take it apart further), and thank you JoeBen for helping, and other folks on the amazing Joby team. You are living the dream my friend.
Enjoy life,
-Luke
brunotollot said:The battery voltage was 24S ??
gwhy! said:brunotollot said:The battery voltage was 24S ??
I belive this was on 12s ~ 4500W
Byte said:Did anyone test a Castle Creations 160HV controller? At what kind of amps do these blow? 60/70A or somewhat?
Dauntless said:Still waiting for Mr. Physics to offer a conclusion, he had much to say before.
If Brun can afford it, maybe these guys can burn thousands of dollars in controllers. Can't wait for my computer to come back so I can see video.
The electrical rpm is all the controller has to deal with.knighty said:do you think the high revs compared to an ebike will make any difference ?
I'm thinking I'll put the other firmware on my controller and limit it to 50 amps and run it on my second bike
but I'm wondering if I could go higher too... the fast switching times running at 6500rpm vs the 650ish max for an ebike must stress the controller more ?
magudaman said:So do they have true current limiting. For example can I set the current limit at say 40 amps and full throttle stall without it cooking?
liveforphysics said:magudaman said:So do they have true current limiting. For example can I set the current limit at say 40 amps and full throttle stall without it cooking?
40amps off the pack is plenty to be sending >4,000amps phase current, and the controller's FETs only feel load from phase current. Many controllers try tricks to estimate, the ones that don't explode actually have dedicated phase-current monitoring with extremely fast hardware gate open interrupts as it see's over-current spikes.
To phrase it differently, battery current limiting can't save a controller, it's not the battery input current that fails them generally anyhow.
magudaman said:... It sounds like your test blew the unit due to heat not current....
