E-Chopper
Hi again
i read the the Battery FAQ but im not sure ......
Last week the weather was fine, so i take the chance to make another short Testride with my D.I.Y Bobber .
I only drive a distance of 5 kilometer to see how it works and check the bike (most under full load "mountainclimbing") .
While i was driving back to my workshop i check the Voltmeter is shows 44Volt (+-1Volt) at full throttle .
Without push the throttle the Voltage goes immediately back to 52,6-52,3 Volt .
Back in the workshop i recharge the battery .
The batterycharger reload the two batterys simultaneously with 2 Amps (i measure it) .
After 4 hour the Charger stop´s... the Batterys was full (56,8 Volt) .
So now my question... if these Batterys were charge with 2 amps 4hours long that means i took 8Ah power from the 40Ah batterypack´s .
Is this thought more or less right
Next question ... how deep can i handle the Voltage ,if 2,5 volt per cell is the bare minimum i must stop driving and recharge at 40 Volt ( measured at full load ) ?!?
I had an Voltmeter on board so i can check the Voltage while drive so is a minimum Voltage of 2.5v per cell *16 = 40v under load ok !??
i dont want to injure the batterys .
What´s our opinion !
My data:
Batterys: 2 pice - pararell(40Ah) -the BMS rechargecable was connectet togehter - 48V 20Ah LiFePo4 - 960Wh- 280*180*110mm- Factory:Wolong
(i think inside one pack there are 16 cells includet BMS)
Motor:HPM3000b- 3KW
Full load amps : my controller gives the motor only max 70 amps .
thanks in advance
Martin
My data:
Motor:HPM3000b- 3KW
thanks in advance
Martin
