i did the same thing. went back to college after working in biomedical research for few years. did not enjoy sacrificing animals. plus back then there were no jobs in biomed research. '73-74.
so i jumped directly into grad school in physics to study solid state, and ended up taking the junior and senior level courses in EE on the side while learning physics. had great EE teacher (he was a big head from Techtronics), but never used it for work since i got into the semiconductor manufacturing business after getting my masters.
i have used this place as way to learn the electronics i never really comprehended then. when you are a student it is all book learning. fixing stuff i like to do so fixing chargers is a good way to force yourself to examine the operation of the circuit. when i was home the last time i pulled out my old electronics textbook, by Millman, "digital electronics" is the title as i recall. it is all right there, emitter followers, common collector, class A, class B, amplifiers.
i had skipped circuits and just read the text and learned to analyze the circuits just from the textbook so it was difficult to go right into the junior and senior level electronics courses. learned to use SPICE and even built a abuncha projects using discrete and then complex ICs, like building op amps from parts, and autoranging DVMs. still have my breadboard projects in a box all these 35 years later.
you can read about how the Switch Mode Power Supplies work in some texts, but now the modern pwm IC controllers are a little different from the older TL494 type of pwm controller. the books are all dated, but i found for the newer type SMPS there was a white paper for the Everbright 816 opto used for feedback to the front end. that white paper is educational about how the newer ICs work like used in the headway charger, and the TI pdf on the TL494 is useful for understanding the older type of SMPS. heath knows a lot too. from experience.
