alfantastic
Info: 9 fet 30A Cellman Infineon, MAC 10T, Ping 48v 15Ah.
1) When limiting the speed via the 3-speed switch, does it act on the controller exactly the same as if you are riding on part throttle?
I.e. Does it only attenuate throttle signal, or is it a bit more technical than that?
The reason I ask this one, is due to reading that it's best to use WOT to help prevent overheating.
On a steep hill on the lowest speed switch setting, could this cause an overheating problem?
Hope you get what I mean
2) Can any damage be done to the controller or motor if the switch is flicked between modes, whilst on WOT?
I.e. If flicking from highest speed setting to lowest when on WOT.
