A123 20AHr Pouch Cell Battery Build & Info Thread
evb said:
That's my battery. I use split pins to connect cells, 3mm aluminium plates to constrict it.
36v 20Ah, 260x180x92mm, 7.5kg
That is damn clever evb. Did you solder to sense wires to the cotter pins? If so what material are they made out of? Great work!
otherDoc
dnmun said:
what is a split pin to you? is it what some would call a cotter key? or a roll pin? have close ups?
Sorry, english is my second language :)
dnmun said:
also what is the BMS you have there? pictures inside?
I bought this BMS from Linda, Headway's manager. Headway installs it to their batteries.
I guess Paul (Cellman) sells it too. http://www.emissions-free.com/catalog/i10.html
yes, solder to it. I guess they are made of steel, soldered well.
thanks, looked like the new headway BMS.
did you consider having the tabs run straight up and putting the split pin on them as they ran side by side, rather than folded over against each other like you did? for space at the top? worried they would touch the adjacent ones?
i wonder if brass split pins would work, or if you need some anti ox where the tabs overlap. way cool though.
yes, I think a battery must be with min sizes for use it on bicycles.
and I guess folded tabs connection (pressed) will be less resistance.
This connection resistance is 0.06-0.08mOm
evb [img said:
http://www.grfasteners.com/docs/images/products/split-pins.jpg[/img]
I looked at this last night, was thinking of keeping the tabs flat against each other and using two cotter pins, facing opposite directions...then solder a balance lead and 2" shrink wrap to finish. Pretty simple and effective!
That does sound like a plan! Between this and those tabs that peterperkins is interested in we are getting some good and relatively inexpensive ways to put a pack together. I'm still holding out for agniusm'a system 'cause I like the elegance but it is good to know there are alternatives. Thanks PGt400 and evb.
otherDoc
maybe someone will try using these spit pins and then use the spot welder on them with the tabs in the middle of the split pin.
soldering to steel is hard, maybe there is some way to pretin that spot and solder in the sense wire before assembling.
really neat and simple idea though.
Those pins look zinc plated, could take solder better..
Here are some interesting ones made of brass.
http://www.amazon.com/1-3-Cotter-Pin-pieces/dp/B003QZJRNC/ref=sr_1_16?s=industrial&ie=UTF8&qid=1336595028&sr=1-16
A lot are stainless but there are some zinc plated ones in millions of sizes. Kool!
otherDoc
Great job, evb. This is my favorite A123 bike pack so far. Easy to build, readily available materials, cheap, good connections. 8)
otherDoc
You do not want any conduction through the pin itself. For long-term function it would be best to even put a little layer of kapton where the pin sits just to avoid the chance of carrying any current through the pin itself.
The pin is there to make clamp load.
So a steel pin would be better ? The brass pins could be squezzed with a vise grips then solder on each end. But solder isn't very strong.
I think a spring-steel pin would be the optimal material.
potatorage said:
How strong are these pin connections? I'd like to find a relatively easy way to hook my batteries up.
I install washer 4mm to end of cotter pin and solder to fix it, I guess it's sufficiently reliable
otherDoc
Please correct me where I'm misunderstanding this pin connection method.
1) The pin allows 2 tabs folded to slip between the pin slit-opening at one end. This applies some minimal contact "force" with the tab material, but I would think not much clamping force.
2) The clamping force shown by EVB's pic shows two 3mm thick aluminum plates that are somehow clamped against the pin.
3) No information is provided how EVB clamps the two 3mm plates to the pin, or how it is bonded to the pin lengthwise with some level of clamping force sustained against the pin. The pin is in the middle of the 3mm two plate "sandwich", so it is the aluminum plate that is somehow supposed to be providing, perhaps the main, clamping force too? :?:
Does anyone understand how EVB is achieving this clamping force with the 3mm aluminum plates? :?: :idea:
How are the two 3mm aluminum plates clamped & bonded to the pin? :?:
I can't find any explanation how to do this...
How did you measure this? What device or exact model of equipment? I'm just wondering about the accuracy of such a measurement based on the test method and equipment used. :idea: :?:
I will try to answer :)
I got an idea clamping aluminum plates from this video
http://youtu.be/GpQcrvRoigc
Somebody guess clamping cells are less resistance. I will test it soon.
Cotter pins idea is mine.
First assembled battery was not so good, it was longer, and with high resistance connections (0.25-1mOm).
I take into account the criticism of russian e-bike forum users and tried to reduce resistance.
I processed all tabs with white spirit for remove stickers adhesive residue and polished with sandpaper.
Then folding tabs several layers and strong press by jaw vice, and fix by cotter pins with washers.
For measure so low resistance I used a simple method:
Connect a battery to load.
Current was 16.2A. I measured voltage drop on place where tabs grow, it was 1-1.3mV.
V/I=R= 0.06-0.08mOm
Maybe it is not so accurate but I guess connection resistance is ok for my applications.
Hi Evb, I watched your video. Thanks. :D
The video does not show what I quote above. :?
Can you make a video that shows how you clamp the tabs and the two 3mm aluminum plates to the cotter pins too? :?:
Are you pressing in the vice only the layers of tabs? :?: In other words, do you press the two 3mm aluminum plates and/or the cotter pin in the vise press too? :?:
I still do not understand clearly. Thank you for your help. :D
You make good videos in English. 8)
:D It's not my video, I only catched an idea :)
It's good idea, I will try to make video, but it will take some time.
I guess you dont realize because think that 3mm plates relate cotter pins, it's no relations or I don't understand you (my english is not so good) :)
no problem, I will try to explain you by picture
Yes, I was mistaken by the photo & by something you wrote too. :oops:
No problem now. I understand thanks to your new diagram. :wink: :D
The 3mm aluminum plate is for the battery box or container for the cells. :p :lol:
Thank you for your excellent diagram. 8)
Hi Evb, :D
I have a question for you...
IF you have to replace a (bad) cell because it fails, then do you think the crushed tabs from the vise pressure can "unfold" & come apart to free the bad cell to replace it? :?: Do you think replacing a failed cell is possible? :?:
It seems it would be very difficult to replace a bad cell and do a repair with all the cell tabs in series and every tab is folded/crushed together? :idea: :?:
Or, could you add a new cell to the end of the stack of cells, and, then, somehow bypass the failed cell leaving it in series too? :idea: :?:
Thanks! :D
Yes. When I assembled this battery, one cell (4th) was bad and I changed it for 30 mins.
unfolded tabs by screwdriver difficult
I guess if change one of cells more 3-5 times, tabs can break
I agree, it is very hard to unfold the tabs once they have been crimped, but it is doable at least once.
I am so glad to see other people demonstrating success with the crimping method. I pioneered the crimping method for these cells in 2010: http://endless-sphere.com/forums/viewtopic.php?f=6&t=12461&start=60#p281360
But my implementation was met with criticism and skepticism, and I was really frustrated by comments from certain "experts" that such a join was resistive enough to heat up when loaded with an "ebike-significant" load, and the tabs would quickly come loose. I proved to myself that a crimped joint could handle the load without heating up - I mean heck both sides of the entire tab is in contact - and two years later those packs are still going strong, so in-your-face to my critics :lol: . If you are building an ebike pack, you don't need a fancy heavy rig to hold it all together, save yourself a ton of hassle and just crimp the cells together.
If you want to put 600a through the cell, a little spot-weld will help:
http://endless-sphere.com/forums/viewtopic.php?f=14&t=29959
I like the cotter pin idea for spot-welding (unnecessary for crimping), because it makes the external clamps I used unnecessary. I can see putting a cotter pin over the end of a pair of tabs instead of the steel strips I used, spot welding through the cotter pin to melt the tabs together, then roll it up and crimp it together. The crimp would carry the load, and the cotter-pin weld would guarantee a weld no matter what happens to the crimp. If you have to replace a cell, unroll the crimp, cut off the cotter pin, and there will still be plenty of tab to spot-weld a new cotter pin.
Luke, you always seem to see an angle I miss, but I don't understand this issue. Since this pin is external to the interface between the tabs, isolated from the pack and outside air with heatshrink, what is the risk here?
-JD
it was my fault for mentioning the idea of a brass split pin, cotter key. i was thinking of the difficulty soldering to the steel, and was thinking brass would make it easier. i had totally missed how ebv rolled this and clamped it in the vise and put the washer on it when i first saw the pictures. now i like JD's idea about using a spot welder first and rolling it up after. just am thinking of the sense wire all the time.
