maybe it would help but i would not cut holes into the covers and mount such little screamer fan to it.. do you have no other options as example mounting a heatsink on outside of the frame and bolt the controller to it?Longshot said:Hey maddin88, if you had to mount that controller interally near your battery, do you think it would help to put a fan between those small vertical ICB and a vent somewhere to cool it?
Longshot said:Uhg, just looking at the stock wire makes me want to open it up and replace it. Nice work! What is your strategy for increasing power? What battery/volts will you start testing with?
Ohbse said:That's beautiful work, well done. What's your intended power/usage to justify the upgrades?
probably i'll try up to 200A battery and 400A phase with MXUS 3T motor. this would be about 14kW with 20s battery.
generally i did this to make the controller more robust and all the more when i read Doc has blown a FET with a very high kV DD motor.
95% i drive not crazy just very normal, but its good to know i can make to bike going crazy if i want
GreenRoad said:good work maddin88
please take care on your copper wire - it could get bad if water comes into the wire - or salt - like in winter - if your are on the road.
If it is possible i never use pure copper wire - if tinned wires are avaiable.....
but its okay ----- only an tip.....
yes thats right. tinned copper is better for corrosion. thanks for the tip.
i thought of using shrink tube with glue for covering the bullets and wire insulation.. do you have other suggestions?
