I bought an Aventon Abound, it uses a proprietary battery connector with a 5 connector plug (2 of which are the power wires)
It has a geared hub motor and a torque sensing bottom bracket, so the controller and torque sensor are a pair as well (hence the display)
the controller is hard-wired to the battery connector block with what seems to be at least 4 wires.
Has anyone here used a battery dual discharge adapter with any of the V2 Aventon bikes? If so, how did you connect it taking into consideration the multiple wires from the connecting block to the controller?
