My apologies for the font - it was not intended to be all caps... this is what happened after pasting.
I DO NOT DO BUSINESS WITH PEOPLE WHO INTENTIONALLY DECEIVE, DEFRAUD AND LIE TO ME. AND TERRY FROM HIGHTEK BIKES FITS INTO THIS CATEGORY. AND IF YOU HAVE A FEW MINUTES TO READ THIS YOU MAY FIND OUT WHY…
TERRY AT HITEK BIKES HAS CHALLENGED ME TO POST THIS INFORMATION SO HERE IT IS… DO WITH IT WHAT YOU WILL. IF YOU WANT TO SIDE WITH TERRY THEN SO BE IT… I DON’T CARE. BUT IF YOU WANT TO BUY FROM AN ETHICAL VENDOR YOU MIGHT CONSIDER LOOKING ELSEWHERE.
I ORDERED AN AMPED BIKES FRONT GEARED KIT FROM TERRY ON OCTOBER 4TH. AFTER CONTINUAL PITCHES FOR HIS AOTEMA KITS. I DID NOT WANT DD.
ABOUT 10 DAYS AFTER MY ORDER THE KIT ARRIVED AT MY DOORSTEP. I OPENED UP THE BOX AND UNPACKAGED EVERYTHING. I WAS DISAPPOINTED TO FIND THAT THE REV2 FENDER EYELET TORQUE ARMS WERE NOT PRESENT IN THE PACKAGE. I HAD BEEN VERY CLEAR ABOUT THESE TORQUE ARMS AS I AM MOUNTING TO A FRONT WHEEL AND I HAVE FENDER EYELETS. WHAT WAS IN THE BOX WAS A USED REV3 TORQUE ARM.
SO I WROTE TERRY AN EMAIL EXPLAINING HE HAD SENT THE INCORRECT TORQUE ARM AND I COULD NOT USE THE KIT WITHOUT THE PROPER TORQUE ARMS. SO HE SENT ME A RETURN BOX FOR THE INCORRECT TORQUE ARM AND MAILED OUT 2 OF THE GRIN REV2 FENDER EYELET TORQUE ARMS. THIS SHOULD HAVE BEEN THE END OF IT… UNFORTUNATELY IT WAS NOT. THE REV2 HE SENT WERE MISSING HARDWARE AND ONE WAS SO BADLY WARPED IT COULD NOT BE USED. THIS IS UNACCEPTABLE IN LIGHT OF THE MANY TIMES I EXPLAINED WHAT I NEEDED AND HE SAID HE HAD. THIS WAS A PURE CON ON TERRY’S PART TRYING TO PULL SOMETHING OVER ON ME WHICH I DID AND DO NOT TOLERATE. IF YOU CAN’T BE HONEST I CAN’T DO BUSINESS WITH YOU PERIOD.
BETWEEN RECEIVING THE KIT AND THE SECOND ORDER OF TORQUE ARMS I FLIPPED MY BICYCLE UPSIDE DOWN AND SET THE WHEEL IN THE FORK. I TIGHTENED THE HARDWARE AND SPUN THE WHEEL BY HAND. THE WHEEL MADE A GRINDING NOISE WHICH IS A CLEAR INDICATOR OF SOMETHING WRONG. I WASN’T BORN YESTERDAY. I HAVE A LOT OF EXPERIENCE WITH BICYCLES AND CUSTOM BUILT WHEELS. THIS WHEEL HAS PROBLEMS. I MADE A VIDEO (WITH AUDIO) OF THE WHEEL AND SENT THAT OFF TO AMPED BIKES (NEVER GOT A RESPONSE).
AT THIS POINT I WAS FED UP WITH TERRY AND HIS CON. HE CLAIMS TO TEST THE WHEELS, BUT AT LEAST IN THIS CASE HE DID NOT. AND ANYONE THAT WOULD TRY TO PASS OF THE MANGLED GARBAGE AS SELLABLE IS NOT TRUSTABLE.
I SENT HIM THIS EMAIL:
I DO NOT APPRECIATE YOU DUMPING OLD USED WORN OUT CRAP ON ME THEN DODGING ME. IN ADDITION THE WHEEL IS MAKING AN INTERNAL GRINDING NOISE THAT IS NOT ACCEPTABLE.
YOU NOW HAVE 2 OPTIONS:
1. SEND A CALL TAG TO PICK UP THE WHEEL AND ALL THE HARDWARE. I WILL RETURN EVERYTHING EXACTLY AS SHIPPED. WHEN RECEIVED YOU WILL REFUND THE ENTIRE AMOUNT BILLED TO MY CREDIT CARD.
2. FIGHT WITH ME AND SEE HOW THAT WORKS OUT FOR YOU.
October 29th – Terry Replies
Terry Says:
FIRST: Please verify there will be someone at your shipping address to give the package to the UPS deliveryman doing the pickup.
Did you think for a second before the accusations, threats, and insults that you may have installed the kit incorrectly? That it could be your fault?
DID YOU REALLY THINK YOU COULD SEND ME BROKEN USED JUNK? OF COURSE IT’S MY FAULT. I’M JUST A STUPID CUSTOMER WITH OVER $10,000 INVESTED IN MY BICYCLES THAT I BUILT FROM SCRATCH MYSELF. MY BROTHER MANAGED A BIKE DEALERSHIP FOR MORE THAN A DECADE AND I HAVE ACCESS TO JUST ABOUT ANY BIKE TOOL I WANT. SO OF COURSE IT IS MY FAULT. ALL I DID WAS PUT THE WHEEL IN THE FORK AND SPIN IT BY HAND. THAT WAS ENOUGH TO KNOW IT WASN’T WORKING PROPERLY. NEVER EVEN PUT POWER TO IT. BLAMING THE CUSTOMER IS JUST GOOD BUSINESS.
For example, did you install a disk brake using the screws off your old disc? If so then they might have been too long and punctured through the motor case, causing the scraping. That’s why there is a warning for that in the kit. You received a brand new, tested motor. I heard back from Ampedbikes and they confirm this kit was tested. They are very interested in the issue and will be involved in the follow up. I have had zero defective units from Ampedbikes in five years.
THAT MIGHT BE RELEVANT IF MY BICYCLE ACTUALLY USED DISC BRAKES. BRAND NEW AND TESTED, BUT NOT BY TERRY (WHO CLAIMS TO TEST THEM, BUT DID NOT DO SO WITH THIS KIT). SO HE IS MAKING THESE ACCUSATIONS WITHOUT EVER HAVING TESTED THE PRODUCT HIMSELF. I ALSO CONTACTED AMPED BIKES AND SENT THEM A VIDEO WITH AUDIO SO THEY COULD SEE AND HEAR THE PROBLEM THEMSELVES. I ALSO SENT IN THE SERIAL NUMBER TO AMPED BIKES. AND NO RESPONSE AT ALL FROM AMPED BIKES WHICH SEEMS TO BE PAR FOR THE COURSE AS HIS REPUTATION IS FAR FROM STELLAR. AM I SUPPOSED TO BELIVE THAT AMPED BIKES HAS NEVER SHIPPED A DEFECTIVE PRODUCT? RIGHT. I’M SURE THAT IS THE CASE – JUST GOOGLE AMPED BIKES AND BEGIN THE READING. I’M NOT HERE TO DISPARAGE THEIR PRODUCT, BUT THEY ARE A VERY LONG WAY FROM PERFECT AND THERE HAVE BEEN NUMEROUS DOCUMENTED ISSUES WITH THEIR KITS.
You can rant on the forums but I will respond and you might actually make yourself look unreasonable or foolish so I would think twice, at least until we know what the issue was.
AND NOW IS YOUR OPPORTUNITY TO RESPOND. GO FOR IT. THE ONLY THING FOOLISH ABOUT ME IS PUTTING UP WITH THE LIES FROM TERRY THE PSYCHOPATH. THE ISSUE IS TERRY! YOU DO NOT PULL THE CRAP HE TRIED TO PULL THEN PRETEND LIKE EVERYTHING IS JUST FINE. SO PLEASE TERRY POINT OUT HOW THIS IS ALL MY FAULT. AND PLEASE EXPLAIN WHY YOU HAVE NOT ISSUED A REFUND. EVERYTHING WAS RETURNED PACKAGED JUST AS I RECEIVED IT. I TOOK THE TIME TO TAKE PHOTOS (MANY PHOTOS) AS I PLACED EACH ITEM BACK INTO THE BOX. I HAVE THE UPS STORE SHIPPING RECEIPT AND ALL YOUR CORRESPONDENCE. SO GO FOR IT. MAKE ME THE FOOL.
No, I don’t want to fight over a $400 order and have the charge floating back and forth for months. I have the refund policy in place as a result of loosing money on several transactions such as: people who have no intention of keeping the product and just want it for a couple weeks then return it used (like they do at the big box stores), people who damage something then return it, people who order expensive custom kits then change their mind and return it, the weather got cold so they return it, or people who couldn’t afford what they bought and need the cash back so they return it.
HE HAS EVERYTHING IN HIS POSSESSION FOR MORE THAN A MONTH NOW AND STILL NO REFUND. NICE MOVE, BLAME THE CUSTOMER AGAIN. WHAT HAS HAPPENED FROM OTHER PEOPLE IS COMPLETELY IRELAVANT TO ME. NONE OF THESE STATEMENTS ARE MY PROBLEM AND DO NOT APPLY TO ME. IF YOU CAN’T RUN A BUSINESS THEN YOU SHOULD TRY A DIFFERENT LINE OF WORK.
I’m convinced you are not a deadbeat or a trouble maker.
AND YET TERRY KEEPS POINTING OUT HOW THIS IS SOMEHOW MY FAULT. MY FAULT THAT TERRY SENT THE WRONG TORQUE ARM, THEN AGAIN MY FAULT THAT HE FOLLOWED UP BY SENDING WARPED DAMAGED TORQUE ARMS MISSING PARTS. AND SOMEHOW MY FAULT THE KIT WAS DEFECTIVE AND HE CLAIMED YOU TEST THEM ALL YOURSELF. AND MY FAULT THAT AFTER A MONTH THERE HAS BEEN NO REFUND ISSUED.
I believe you actually think you got a defective product based on your passionate statements.
BLAMING ME AGAIN. LIKE I’M TOO STUPID TO KNOW THAT A WHEEL THAT IS GRINDING IS NOT FUNCTIONING PROPERLY.
I have a perfect record in eight years, no chargebacks, so I must be doing something right, and would like to keep that record. Besides, I don’t think this particular charge is worth fighting over, there are too many questions and it’s not a clear case, so I’m fine with making an exception and issuing a refund.
SO YOU SAY. THERE YOU HAVE IT FOLKS THIS GUY IS PERFECT… WRITTEN STATEMENT THAT HE IS GOING TO ISSUE A REFUND. FUNNY HOW IT IS NOW DECEMBER 27TH AND WHILE EVERYTHING HAS BEEN RETURNED STILL NO REFUND.
WHY DOES THIS PERFECT BUSINESSMAN OPERATE OUT OF A UPS DROP BOX AND NOT A LEGITIMATE STREET ADDRESS?
WHY IS HIGHTEK BIKES NOT CURRENT WITH THE STATE OF CALIFORNIA AND OPERATING WITHOUT A BUSINESS LICENSE? EIGHT YEARS IN BUSINESS AND NO STREET ADDRESS AND NO BUSINESS LICENSE? ABSOLUTELY PERFECT!
This was a totally bizarre transaction, seems it was jinxed from the beginning. Very unusual. We both agree, it’s best you start off fresh with another company. Also, it’s good to find a vendor you are comfortable with and establish a relationship for purchases in the future. Hope this doesn’t sour you to ebikes in general, they are generally trouble free and work great. The kits do require some care for proper installation though.
ONCE AGAIN BLAMING THE CUSTOMER. AND STILL NO REFUND. THIS IS KIND OF A RECURRING THEME AT THIS POINT… BLAME, BLAME, BLAME. DIDN’T I READ THAT HE IS CONVINCED (THAT’S A BIG WORD) THAT I AM NOT A DEADBEAT OR A TROUBLE MAKER BUT HE HAS TAKEN NO STEPS TO REFUND THE TRANSACTION?
“Those little torque arms aren’t something I normally stock, I had those two available, I believe I used them for testing once. I knew you needed them fast, so I sent those. I try to accommodate special requests but sometimes it doesn’t work out. You are right though, you should either stock it or don’t sell it, and I have since decided not to sell those as they don’t work well. “
“I believe I used them for testing once”
REALLY. ONCE? TESTING? THE TORQUE ARM WAS CLEARLY MANGLED, BENT BEYOND USE. IT’S INEXCUSABLE TO SEND SOMETHING LIKE THIS… IN ADDITION IT WAS MISSING THE MOUNTING SCREWS. YOU DON’T PICK UP A HANDFUL OF WORN OUT PARTS AND SEND THEM OUT LIKE HE DID. THERE IS NO OTHER PERSON TO BLAME, HE’S A ONE MAN SHOP IT APPEARS AND HE HAS MADE NO EFFORT TO BLAME ANYONE ELSE BUT ME.
“and I have since decided not to sell those as they don’t work well “
I’D BET THE JUSTIN FROM EBIKES.CA WOULD BEG TO DIFFER. THESE ARE HIS GRIN REV2 FENDER EYELET TORQUE ARMS IN QUESTION. I HAVE READ ALL THE FORK TESTS POSTED ON ENDLESS SPHERE AND THE TESTS DONE ON THE EBIKES.CA SITE AND THESE TORQE ARMS NO ONLY APPEAR TO WORK, THEY APPEAR TO WORK VERY WELL.
From another correspondence:
You bring up some good points and have some good questions. You have a pretty good idea of what’s out there, although some of the info you got from the Sphere forum is wrong. You have to sort through various BS, crap, and just plain wrong information.
I don’t respond to comments on bike forums, as I mentioned most of the info on them is wrong.
GOOD TO KNOW THAT MOST OF THE POSTS ON ENDLESS SPHERE ARE WRONG. I’VE READ THOUSANDS OF THESE “WRONG” POSTS AND I FIND THERE IS A LOT OF CREDIBLE USEFUL INFORMATION.
BECAUSE TERRY DIDN’T KEEP HIS WORD AND CONTINUES TO TRY AND SCREW ME OVER I HAVE POSTED THIS MESSAGE (SAID HE WOULD SEND UPS TO PICK UP THE PACKAGE). THIS WAS FOLLOWED BY AN EMAIL ABOUT 10 DAYS LATER THAT THEY DON’T DO PICK UP WHERE I LIVE. SO THEN HE SENT ANOTHER EMAIL WITH A STICKER TO PRINT (WHICH I PRINTED, DROVE TO THE UPS STORE AND RETURNED). IT’S BEEN MORE THAN A MONTH THAT HE HAS HAD THIS KIT IN HIS POSSESSION AND STILL NO REFUND.
AND HERE IS WHAT HE REPLIED TO THE CREDIT CARD COMPANY AFTER I FILED A COMPLAINT. HAD HE DONE WHAT HE SAID HE WAS GOING TO DO I WOULD NOT HAVE NEEDED TO FILE A COMPLAINT.
Talked with customer regarding problem. Consulted with supplier and confirmed unit was tested before delivery and determined unit was damaged by customer by incorrectly attaching a part despite clear warning label. Offered free repair to customer and partial refund. Customer has refused to send product back before chargeback so it can be examined, and has instead sent abusive and threatening emails. We have no refund policy but support our customers with a good warranty. Have photo of warning label attached, showing it taped to the spokes so it is impossible to miss. Was not able to upload will send by mail.
“determined unit was damaged by customer by incorrectly attaching a part despite clear warning label”
HOW EXACTLY DOES ONE DETERMINE THAT A “UNIT” WAS DAMAGED BY A CUSTOMER WHEN THEY HAVE NEVER EVEN TESTED THE UNIT? KEEP IN MIND THIS LIE WAS SENT TO THE CREDIT CARD COMPANY BEFORE HE HAD EVEN SEEN THE WHEEL RETURNED AND HE HAD NEVER CHECKED IT OUT HIMSELF. I HAVE PHOTOGRAPHS OF THE UNDAMAGED WHEEL BEING PLACED IN THE BOX FOR RETURN. I NEVER APPLIED POWER TO THE WHEEL OR THE CONTROLLER. AND DID TERRY SEE ME INSTALL THE KIT?
“Customer has refused to send product back before chargeback”
ANOTHER LIE. I WAITED AROUND EVERY AFTERNOON FOR MORE THAN A WEEK FOR THE UPS DRIVER TO SHOW UP… BUT HE NEVER DID. THEN AFTER I FILE A COMPLAINT WITH MY CREDIT CARD COMPANY I GET AN EMAIL STATING THAT UPS WON’T PICK UP FROM MY AREA. SO I HAD TO PRINT THE SHIPPING LABEL AND DRIVE THE PACKAGE TO UPS WHICH I DID AS SOON AS I WAS AVAILABLE. SO IT’S CLEARLY MY FAULT THAT TERRY CAN’T EVEN DO WHAT HE SAYS HE WILL DO.
“and has instead sent abusive and threatening emails.”
ABUSIVE? IS IT ABUSIVE TO DEMAND A VENDOR SHIP YOU PRODUCT IN NEW CONDITION AND DO WHAT THEY ACTUALLY SAY THEY WILL DO? AND PLEASE POINT OUT THE THREATS. WHAT EXACTLY DID I THREATEN? THAT I WOULD FIGHT YOUR LIES WITH MY CREDIT CARD COMPANY? WHO WOULDN’T DO THAT?
AND I HAVE A I DO NOT DEAL WITH COMPULSIVE LIARS WHO SHIP BROKEN PARTS POLICY. I’M ALSO FINE WITH WRITING AND EXPRESSING MY CONCERNS TO THE ATTORNEY GENERAL OF THE STATE OF CALIFORNIA. GOOD LUCK WITH THAT. GET READY TO CRACK OPEN THAT CHECK BOOK AND PAY THOSE BACK FEES.
AND WHERE DID THIS MAGIC PHOTO APPEAR FROM SEEING HOW YOU NEVER EVEN TESTED THE UNIT? GO AHEAD AND FABRICATE THAT PHOTO.
BOTTOM LINE IS THIS GUY IS TO BE AVOIDED AT ALL COSTS. IF THIS IS HOW HE DEALS WITH CUSTOMERS WHY WOULD YOU EVEN WANT TO TAKE A CHANCE. NO REFUND POLICY? ARE YOU KIDDING ME… NO ONE TAKES PERSONS MONEY, SHIPS THEM DEFECTIVE AND USED EQUIPMENT AND THEN EXPECTS TO BE PAID. WELL NO ONE WHO IS NOT SELF DELUSIONAL. BUT AGAIN IT’S UP TO YOU. IF THIS IS HOW YOU WOULD EXPECT TO BE TREATED THEN BY ALL MEANS OPEN UP YOUR CHECKBOOK AND DO BUSINESS WITH HIM.
I HOPE THE MODERATORS WILL ALLOW THIS POST TO REMAIN. I ACCEPT FULL RESPONSIBILITY FOR ALL OF MY WRITTEN STATEMENTS. I’M NOT LOOKING TO START A FLAME WAR… I JUST WANT TO EXPOSE THIS UNETHICAL PERSON SO THAT OTHERS CAN AVOID THE MISTAKE I MADE BY TRUSTING HIM WITH MY MONEY.
I HAVE DOZENS OF EMAILS TO BACK UP EVERY ONE OF MY WORDS. I HAVE PHOTOGRAPHED EVERY ITEM AS I TOOK IT OUT OF THE BOX AND AS I REPACKAGED IT.
IF TERRY WOULD LIKE TO SUE ME THEN HE CAN DO SO. HE HAS ALL MY PERSONAL INFORMATION ON FILE. BRING IT ON. THE TRUTH IS NOT LIBEL.
TERRY YOU DON’T GET TO TRY AND CON ME, TAKE MY MONEY, TAKE BACK THE PRODUCT, THEN PRETEND LIKE YOU DON’T HAVE TO ISSUE A REFUND. I’M NOT THE BAD GUY HERE – YOU ARE… I’M JUST A GUY WHO TRIED TO BY AN EBIKE KIT AND GOT DUPED.
TERRY - PLEASE FEEL FREE TO DISPARAGE AND BLAME ME FOR YOUR INADEQUACIES AS A HUMAN. AND PLEASE PAY YOUR FILING FEES AND BUSINESS LICENSE FEES TO THE ATTORNEY GENERAL OF THE STATE OF CALIFORNIA SO YOU CAN AT LEAST APPEAR TO BE LEGITIMATE.
TO EVERYONE ELSE… HERE’S WISHING THE BEST NEW YEAR AND MANY MILES OF HAPPY RIDING!
