That's strange.
Even the andersons I have had on bike things for years that are in the weather don't corrode or fail in the way you've had, including the stuff tha'ts on the bottom of the SB Cruiser trike that's been submerged more than once in flash flood waters. Most of the time it's pretty dry here in Phoenix, AZ, but when it's wet it's really really wet.
Most of my connectors are SB50, but some are PP45, including my frequently-used 12A charger connection (charger is built in, mounted on the bottom of the trike, connected to the controller side of the CA shunt and back to the battery via the PP45's), and the phase connectors to the left side motor.
I'm curious what the specific differences are between your setup / usage / conditions and mine are, that you have such bad corrosion on them and I don't, so we can use this info to help others not have such problems.
BTW, who were you replying to in today's post? (you're the last person to post before that one, a couple years ago).
If it's useful to anyone reading this thread, I have some posts around the forum that describe the limitations of the powerpole / SB connector design, and the way they should be used to prevent problems with them. We have a knowledgebase in the process of being setup, and I'll consolidate that info there once it's ready, too.
Some of the posts s hould be in this list
endless-sphere.com
