kfong
Wow, what process did you use to drill all those holes. The fact that it ran the length of the can was really impressive machining.
I'm with you on limiting the fun . I assume you have a CA-RC and thats how you are limiting your current. If so didnt you get the supplied 2 little shunts? My understanding of going over a shunts current range means it becomes hot and starts to act like a fuse?
Wow, what process did the use to drill all those holes. The fact that it ran the length of the can was really impressive machining.
Time to uprade to a 3220, piss the gears off and start pulling power monos
motomoto said:I think Astro Flight will send me a 3220 4t towards the end of the week, thanks to Matt.
By that time I will have the shunts and new wiring done and some nano techs. I want to do
a new 'run through the gears' video with the bigger motor and the amps turned up.
motomoto said:I just got home a few minutes ago and there was a FedEx sticker on my door. It is for my 3220 4t from Astro Flight.
I should have things running this weekend and do a video. All I have ever run are 3210s. The 3220
should be double the power. It will be amazing if it is. I'm like a little kid and it's Christmas.
motomoto said:2 new videos
http://youtu.be/JUOXhDYfsL0
