dumbass
I am mounting 2 – 24v x 450w Ezip brushed motors on an Ezip bike in the “V†frame. I already have the 2 motors, 2 controllers and 2 throttles. They will be powered by 2 battery packs each pack is a 24v 20ah Thunder Sky pack (24v*40ah total). As of this morning my Ezip is now equipped with a Nuvinci CVS hub.
I do most of my riding in the forest preserves where my speed is limited so I could run on one motor. But now and then I hit the roadways to get to the forest preserve. For this I would like higher speeds.
My question is, is it better efficiency wise to run one motor when I am riding slow and both when running fast? Or does it really make any difference? Setting up to run one selected motor is a PITA. Not because of the controllers and throttles but because of the extra freewheels required. I can not mount a freewheel directly onto the motor and will need to use a jack shaft. But this will only require one freewheel if the 2 motors run together. But to make them independent it will require a second freewheel and this takes more space. And frankly it doesn't look as good.
If it is just as efficient to run both motors all the time I could then do as Kurt did and run the motors at 48v in series. But the stock Ezip controllers are 24v at 35a. So wouldn't I want a 48v x 70a controller to acheave the max prower from both motors? The biggest 48v controller I've seen is 1200w which is only 25a. Right??
