Hillhater said:
Chalo said:
Ratios don't tell you everything you need to know. Gear inches (or meters development) are proportional to ratio times wheel diameter. That's what you need to know to make relevant comparisons.
Sorry Chalo,..i respect you but... Gear inches tell you nothing !
Its simply a number to compare with previous numbers.
If you want to alter that number , you have to start thinking in terms of sprocket teeth and "ratios'.
..and how long is it since there was any serious option for wheel diameter on road bikes ?
I've worked on road bikes with ISO 406, 451, 520, 540, 559, 571, 584, 590, 597, 622, and 630 sized rims. Even if you normalize for 700c (ISO 622) wheels, a 700x20 tire doesn't have nearly the same circumference as a 700x60 Big Apple.
Using customary gear ratios won't get you what you want with a bike like this:
But if you know you want a 40 inch low gear, then you'll have a quick idea of what you need to do to accomplish that.
