jakeyb2525
- Joined
- Oct 2, 2015
- Messages
- 83
Hi all,
Im currently an E-go owner and unfortunately its not fulfilling my needs!
I'm 6ft 7" and just over 16st 108kg so i'm pushing the recommended Maximum load capacity to its limits!
The area i live in is mainly hills! so opening my door and going for a ride is not really worth it on my E-go
My last logged ride in my area:
Distance 5.8 mile
Moving time 1:03.48
AVG speed 5.5 Mph
Obviously riding on flat ground is a lot better but still not ideal due to my size and weight, the top speed gets boring and definitely leaves you wanting more!
So here i am...I've been doing a bit of research and reading, trying to figure out what build will be best for me, i don't really want to go down the dual motor route just yet as i want maximum run time, i'm just hoping i can achieve the torque i need from a single motor set up, around 18 mph top speed and 10 mile range would be ideal, but obviously my main aim is climbing power from a single motor!
this is what I have come up with:
*Quanum 2.4Ghz 3ch Pistol Grip Tx & Rx System
*Turnigy Aerodrive SK3 - 6364-190kv
*Hobbywing EZRUN 150A PRO
*Enertion Single Motor Mount Pro Kit
*4 x 3s 5000mah 2 x parallel and 2 x in series for longer ride time
*LED Program Card For Hobbywing eZRun
I'm assuming the gearing will come 14/36 from Enertion, will this be ok? or will i need a smaller pinion gear and larger drive gear for torque?
I would like to go with a wiiceiver and VESC but finding them in the UK is a nightmare!
I'm going to start ordering my parts on Monday so wanted a bit of feedback before i do, any help is appreciated, Thanks Jake
Distance 5.8 mile
Moving time 1:03.48
AVG speed 5.5 Mph
