john7700
Just to preface, I am not very knowledgeable about electrical matters and this is my first
venture in to E-biking.
So, I went out and bought a volt meter so I would have a way to check things out and after
fooling around a little I decided to check the amperage on my 36v 30AH Ping. I set the meter
to amps and touched the test leads to the battery leads and promptly blew the hell out of my new
meter with a loud pop and spark. Every thing seemed ok with the battery and after about two
weeks of getting a bunch of stuff worked out with the rest of the motor, bike, etc. I had every thing
running well. I took the bike for a long ride yesterday and ran it until it started to cut out so
I could begin to judge my distance range. Every thing worked well and I got about 22 miles out of
my 9c before it began shutting down. Parked it in the garage and shut the controller off, plugged in
the charger and shut the lights off in the garage. Just went out to check on it tonight and it is not
charging. I did had the controller shut off but I didn't think that should matter. I just turned it on
and have it on the charger hopping it will charge up?
So, my question is, did I blow the BMS ? I'm sure I'll know in a few hours but this is killing me. What
say you most knowledgeable Sphere folks.
Thanks,
John
Thanks,
John
