OK, a couple issues with this mod:
1) The brake cutoff switch no longer kills power. I verified the switch is working, but the CA throttle input seems to bypass the cutoff. With the standard throttle setup, it worked.
2) The cruise control (crystalyte unit into crystalyte analog controller) no longer works correctly. Upon initial "set", the bike slows way down. On hitting the + button, the CA current limit is exceeded. Before the mod, "set" would keep the bike at the commanded speed, and the CA current limit would keep everything in check.
I'm actually enjoying the current throttle with my Magura throttle & Oury grips. Turning IntAGain down to 200 from 300 helps smooth it out too, though it's slow off the line. At 300 it would spin the wheel in the wet, which almost took me out on an off-camber start.
I also had an intermittent speedometer problem yesterday. On the ride home Tuesday it poured, but it was dry yesterday. The CA was displaying 0mph while I was moving, but occasionally the speed would jump up to 80mph, 120mph, 400mph, 600mph! When the 99mph limit was violated, the CA cut throttle
I had to set the wheel diameter to 1mm to get home.
Upon troubleshooting tonight, 24 hours later, it worked perfectly right away. I opened up the CA and there was no moisture, no shorts, no broken connections, no smells. Hmm. Perhaps the wheel speed sensor had some water issue, or a partially broken wire?
